6.0 harness and PCM, will it work with a 5.3 engine?
Old 10-10-2011, 12:15 PM
bjamick's Avatar
Default 6.0 harness and PCM, will it work with a 5.3 engine?
I'm actually going to be installing a 5.3 into a denali that is DBC. I was just wondering if the 6.0 harness and PCM will work with a 99-02 5.3 engine?
I'm thinking it should just be a plug and play, but figured I would ask and see. I also think it has the 4l80e trans in this 02 denali.
Old 10-10-2011, 12:19 PM
the_merv's Avatar
Yup, it'll work..you will have to adjust the tune for it.
Old 10-10-2011, 01:33 PM
bjamick's Avatar
Alright cool, I don't think that should be to bad then. Is it just fueling that is the problem?
Old 10-10-2011, 01:45 PM
the_merv's Avatar
Well kinda..if you saw it you's understand it..alot of factors.
Quick Reply: 6.0 harness and PCM, will it work with a 5.3 engine?
