what size AN is the factory power steering hose on a LQ4? can i cut it and...
Old 11-19-2011, 07:33 PM
SIKHS 5's Avatar
Default what size AN is the factory power steering hose on a LQ4? can i cut it and...
i was wondering what size the factory power steering hose is in AN(2002 LQ4) - im thinking about cutting it to the desired length and using a hose end like this then a adapter from Xan to inverted flare into my factory gearbox
would this work?
Old 11-19-2011, 11:33 PM
Fahrenschnell's Avatar
It will work....but for $20 bucks you can take the line to Napa and they will put the correct end on it for the chevelle. I Just did this on my 64 Chevelle. Works like a champ.
BTW....I tried the AN fitting route and even used crimp fittings but it leaked.
Old 11-20-2011, 02:52 AM
MikeFSKSpeed's Avatar
Honestly as was said the best route is get one made. Even if you found a close size fitting, AN fittings require a pretty specific ID/OD to make a positive seal. I think you'd just be asking for a high pressure fluid spray
Quick Reply: what size AN is the factory power steering hose on a LQ4? can i cut it and...
