Dbw issue
Dbw issue
I have a 84 Chevy caprice coupe with a 5.3l motor. Car has dbw setup with a 4l60e. The car is running but no response from pedal. When I crank it if I barely push pedal it responds. If I push it more than a quarter of play it stops responding until I turn off an crank again. Any help would be appreciated.
Not sure if it helps or not, but I have a bad ground to the tac module. Used a good solid ground, and it started working great. Might check you're basics to, like connections, other grounds, etc.
LS1Tech Sponsor
Two questions....
1. Do you lose switched power to the engine harness when you are cranking?
2. Does the pedal work if the key is ON but the engine is NOT running?
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
LS1Tech Sponsor
Ok....
1. What tune is in the PCM?
2. What tac module and pedal are you using? Truck or Vette?
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
Using truck pedal and tac. Was using corvette pedal and tac an didn't get a response from corvette setup. Don't know about the tune but the truck pedal works till I push pedal 1/4 of the way.
LS1Tech Sponsor
Need to know what tune you are using. Cant interchange them.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
