1997 corvette alternator,how do I wire it to work without PCM??
1997 corvette alternator,how do I wire it up to make it work without pcm???i been searching all Over the forum and I seem to get conflicting information!i called S&P performance and mark there told me pin D goes to solid 12 volts and pin C goes to 12v switched on by key!!is this correct??
Assuming this is a CS-130D,
Pin D is voltage sense usually goes to battery.
Pin C is field control goes to PCM so PCM can control alt output. (C2/11)
Pin B is lamp control. On stock setup is goes to PCM (C2/77)
If you're running it non-PCM controlled can just use pin B to the lamp. If not using a lamp put a resistor inline to switched +12; 560 ohm 1/2 watt will do the trick.
1997, alternater, alternator, alternators, aternater, connector, controlled, corvette, driven, make, operate, pcm, wire, wiring, work
