cts-v oil pan and ls swap mounts?
Time to start purchasing some parts for my swap. Wheres the best place to purchase a complete cts-v oil pan? Also need swap mounts to install an lq9 in an 83 Caprice. Thanks
i purchased mine from jegs or summit for 150$ came with everything its called the muscle car pan its supposed to fit any older model gm frame my vehicle is a 73 nova. As far as mounts go im having mine made from a template i found on here but i would check with some other members maybe they will chime in on your application
I used standard mounts I bought from Summit for $45 but had to move them back about 1.5" anyway. Used a CTS-V LSA pan I got off Ebay for less than $200 and it came with pan, widage, dipstick and tube, and gasket. No bolts however, I just used the ones from the truck pan I took off.
I bought those damn things like 7 months ago. I bought them from Summit for like $40. Downfall I shoulda ordered the 1" setback plates. There are plenty of pics on my thread in my sig.
The muscle car pan is a truck pan (not sure which truck) and it sits very low. The CTS-V pan does not sit quite as low, and is shaped a little different - the sump isn't quite as deep.
