Vacuum Leak
Old 05-04-2012, 11:25 PM
neal64ss's Avatar
Default Vacuum Leak
I have my 5.3L swap in a 64 chevelle running, but it runns "rough" and the LTFT readings are maxed out at +25%. If I understand this correctly, it means that the engine thinks it has a lean condition but is usually caused by a vacuum leak which is putting more air in the engine than expected, and the PCM is adding fuel in an attempt to correct this condition.
I remember when I put the valley cover on that the gaskets/grommets that go in the valley cover where the knock sensors are were not in the best of shape and I never got around to changing them before I put the engine in the car. Could my vacuum leak be from this area? Anyone have any experience with this?
Old 05-05-2012, 10:39 AM
bmf5150's Avatar
I would google or look on YouTube on how to make a DIY vacuum leak smoke machine and try that first to pin point the leak!
Old 05-05-2012, 10:44 AM
bmf5150's Avatar
http://forum.e46fanatics.com/showthread.php?t=445181
Quick Reply: Vacuum Leak
