Turbo lsx fox body questions
Has anyone used a B&G kit? or is it cheaper to go with 6.0 manifolds?
http://bgturbokits.com/storebg/index...products_id=24
I personally dont have any experience with his kits but alot of people on The Turbo Forums seem to like him.
http://www.theturboforums.com/smf/tu...iews/bg-turbo/
The way I see it, if u go with the truck manifolds u can decide turbo placement, exhaust placement, and how u route the cold side.
I guess what it will come down to is how much work do u want to put into it.
I did the BG kit when I was running a 302. Kit was okay, customer service top notch. After fighting with header flange leaks for two years I cut it up and used the V bands and piping for my truck manifold kit. Building a kit is easy and you get to save yourself some money. If the LS kit is anything like the ford stuff good luck getting at your plugs. The truck manifolds won't leak and you can route the downpipe wherever you want.
