LT to LS swap f body
Old 06-25-2012, 12:45 PM
Houston_t's Avatar
Default LT to LS swap f body
Just curious if a lt (v6 or v8 ) to ls swap can be done without changing over to the ls cradle. Just trying to weigh out my options. Thanks
Old 06-25-2012, 12:50 PM
93Z2871805's Avatar
There are adapter mounts to bolt an LS where a SBC mount used to be. From what I've heard from others that have used them, swapping the k-member is better.
Old 06-25-2012, 12:56 PM
Houston_t's Avatar
Seems like it would be easier to just use adapter plates as to swapping out the cradle. And cheaper, but the few swaps I read up on so far all used the cradle so I was curious. Just trying to keep cost and labor down.
Old 06-25-2012, 01:05 PM
93Z2871805's Avatar
From what I understand the adapter mouts are more of a pain than they are worth. And as for labor, FWIW, I installed my motor from the bottom, complete with intake, headers, TB, solid motor mounts, and K-member, without putting the rear wheels up, using two jack stands, an engine hoist, and a floor jack, by myself. Honestly getting the new motor in was the easiest part of the swap.
Old 06-25-2012, 01:18 PM
Houston_t's Avatar
So all I would need is the cradle ? Or are there other parts involved
Old 06-25-2012, 01:27 PM
93Z2871805's Avatar
For mounting the engine, it's just the K-Member and motor mounts.
Old 06-25-2012, 02:35 PM
Houston_t's Avatar
so can anyone answer why it would be better to use the cradle over swap plates ?
Old 06-25-2012, 05:10 PM
Rick Speed's Avatar
From what I remember everyone that use swap mounts had issues with fitment. Just find a cradle. I got my cradle for $50 wich is less then swap mounts anyway
Quick Reply: LT to LS swap f body
