Need alittle info
Old 07-02-2012, 10:43 AM
mwalkrt's Avatar
Default Need alittle info
Ok guys Im new to this site and looking for a bit of help. Ive got a 94 Silverado I'm stabbing a 6.0L in. If that wasn't enough Im adding a pair of turbos to it. Ive had to make a pair of forward mounted headers simply because I couldn't find any complete. Ive got a harness and ecm programmed. As far as sensors IDK. MAP sensor is no problem. Will I need a boost sensitive MAF sensor. Also the vehicle that the motor came out of had an internal fuel pump modual. Is there a boost sensitive regulator kit to relocate to the rails? Im wanting to use an aeromotive inline pump. And what about O2 sensors? Will the oem work
Old 07-02-2012, 12:23 PM
Adam123's Avatar
Ask your programmer if he programmed with Speed Density. If he did you won't need the MAF. You'll need 2 bar or above MAP.
If it's a truck 6.0l like an lq4/9 there were regulators on the rails. But I'd buy a boost reference fuel regulator.
A1000?
You only need the front 2 02s and I'd recommend widebands as well.(for tuning)
Old 07-02-2012, 11:04 PM
mwalkrt's Avatar
Thanks for the help Adam
