Couple pictures of my nissan 240sx 5.3 turbo build
Old 07-17-2012, 11:12 PM
turbociv910's Avatar
Default Couple pictures of my nissan 240sx 5.3 turbo build
Ive got a 1992 nissan with a 5.3 iron block mated to a th350 for drag racing. Id like to share some of my build pictures-
"chassis-
-8 pt cage
-stripped/gutted
-daft eng mounts
-sikky solid sub mounts
-5 lug swap
-q45 front brakes
-fenders pulled
-rims undecided but running a 26" slick
engine-
-m800 ecu
-motec e888 expansion for EGT, EMAP and other.
-motec sport dash logger
-chase bays ls1 harness
-rebuilt heads
-trick flow springs
-gto oil pan
-new oil pump
-MLS gaskets
-ARP bolts
-tsp push rods
-ls1 intake/tb
-lingenfleter gt2-3 baby cam
-ls1 accessories(f body)
-bosch 1000s
Transmission-
- SFI JW Ultra Bellhousing
- SFI Trans Scatter Shield/Steel
- Alto Red Clutch Packs
- Coan 300M Billet Input Shaft w/ Billet Forward Drum
- Hughes Pro Brake
- Hughes Case
- Hughes Manual Reverse Pattern Valve Body
- Coan Direct Drum w/ 36 Element Sprag "
Drive Train-
-Q45 3.53 differntial
- 300zx TT axles and hubs
-Custom drive shaft
-15x8 rims
- 26x10 drag raidials
no hood, bumper, turbo kit or me in it.
started on the driver side-
got it tacked up
bosch racing 90lb hr injectors!
started on passenger side!
turbo inlet(going to make a fiberglass duct through the head light cover)
oil pressure sensor to log pressure in the motec-
Old 07-18-2012, 07:43 AM
turbonola's Avatar
awesome, i'll be using megasquirt myself
Old 07-18-2012, 03:04 PM
5.0seven's Avatar
awesome. It looks good so far. It looks like you have a ton of room between the frame and motor. Im jealous
Old 07-19-2012, 11:04 AM
Nissan LS240's Avatar
I miss building my LS1 240, now if I could keep it from breaking I'd love it more, yours looks pretty good so far
Old 07-19-2012, 11:44 AM
Project GatTagO's Avatar
Received 1,417 Likes on 893 Posts
Nice build...
Andrew
Old 07-24-2012, 08:29 PM
got a little more work done-
Old 07-25-2012, 10:00 AM
My1stFBody's Avatar
Maybe its just me, but that turbo looks huge in there!
Old 07-25-2012, 11:27 PM
its to small!
got it started for the first time, everything was looking when he was adjusting the fuel
https://www.youtube.com/watch?v=Px1yuqsKHxU
Old 07-26-2012, 09:49 PM
Old 07-27-2012, 12:49 PM
28x10
Old 08-25-2012, 02:43 AM
turbonola's Avatar
thats intimidating
Old 08-25-2012, 10:15 PM
twoeyes12's Avatar
Curious what kind of pistons & crank/rod bearings did you use.
Miles on engine?
Old 08-29-2012, 10:53 PM
stock block, just head studs, 133k was advertised.
Old 08-31-2012, 12:32 AM
Slo_240sx's Avatar
Very nice, its similar to mine. I had a 5.7 with GT45 but I ended up dropping two cylinders. Right now I'm building a 370 and GT4788. Looks good, you have some good parts on there. How do you plan to run the exhaust?
Old 09-01-2012, 02:58 AM
1998_z28's Avatar
car looks good taylor might be back working on my rx7 sooner than planned
Quick Reply: Couple pictures of my nissan 240sx 5.3 turbo build
