84 chevy truck lsx swap parts list
Old 09-12-2012, 07:59 PM
1fastmofo's Avatar
Default 84 chevy truck lsx swap parts list
id like to start a thread to post what you have found that makes this swap easier and potentially cheaper. so far this is what i have
1) fbody headers are a near flawless fit
2)i personally am going to run my th400 and ive found that this guy has explained everything
http://www.pirate4x4.com/forum/showp...04&postcount=1
3) this adapter will allow you to run an aftermarket oil gauge for the lsx motor
http://www.speedwaymotors.com/LS-Ser...ter,20928.html cost $11
4) i personally am going to make my own motor mounts just because i have the steel a plasma cutter and a drill press. heres a link
https://ls1tech.com/forums/conversio...es-prints.html
I have read that the blazer and sub gas tank are in the rear of the frame this could be a bonus to guys lookin for more traction, I plan to run an efi tank and hopefully get a walbro to work within that fuel tank hat possibly a 255
I would like to find a cheaper alternative to the novak ac relocate system
also more options for gauges. both options ive found on these seem to be expensive and out of my personal budget goal.
Old 09-12-2012, 08:01 PM
1fastmofo's Avatar
3) update cheaper thru summit http://www.summitracing.com/parts/ATM-2268/
Old 09-13-2012, 05:01 PM
sweetk30's Avatar
i found a free way to use truck manifolds and down pipes in the 73-87 trucks . https://ls1tech.com/forums/conversio...xaust-mod.html
my 85 build thread https://ls1tech.com/forums/conversio...l60e-swap.html
Old 09-13-2012, 09:32 PM
1fastmofo's Avatar
has anyone else heard of runnin an efi blazer or burban tank and have pics of the rear mount?
Old 09-13-2012, 10:07 PM
74modified's Avatar
How cheap can you do #3? Free if you have an 1/8"NPT tap.
On left is oil cooler bypass or right is original oil pressure sender - it was broken anyway. Both drilled and tapped.
If you are running the R4 compressor take a look at this
http://www.maliburacing.com/forum/vi...p?f=34&t=79059
Old 09-14-2012, 10:53 AM
mooseknuckles's Avatar
I have a blazer tank in mine, not the efi tank tho.... had I of known at the time I'd be doin an LS swap. I would've got the 87 tank... the tank is 28"x 28 1/4" x 10" deep. using the stock tanks straps and '86 sending unit, and external whalbro 255 pump....keep in mind I have a raised bed floor, so the tank is mounted up high, and not visible from the rear....also I welded a 2x4"x1/4" across the rear frame rails for some protection.....
Attached Thumbnails 84 chevy truck lsx swap parts list-410.jpg   84 chevy truck lsx swap parts list-411.jpg   84 chevy truck lsx swap parts list-412.jpg   84 chevy truck lsx swap parts list-413.jpg   84 chevy truck lsx swap parts list-415.jpg
Old 09-14-2012, 06:29 PM
sweetk30's Avatar
and if using blazer or truck efi tank setup you can use 96-97 chevy c/k 3500 5.7 motor fuel pump. direct swap and plug in on older sender unit. 60 psi spec .
Old 09-14-2012, 06:52 PM
1fastmofo's Avatar
this is great info lets keep it coming fellas i know myself Im without a doubt going that way for the ac "modified"
Old 09-14-2012, 06:55 PM
1fastmofo's Avatar
what about electric fans?? ive got a set off a fbody anyone tried em?
Old 09-21-2012, 02:14 PM
griffin dual pass universal rad comes with 12" dual electric fans....
Attached Thumbnails 84 chevy truck lsx swap parts list-668.jpg   84 chevy truck lsx swap parts list-770.jpg
Old 09-21-2012, 06:59 PM
sweetk30's Avatar
did some lookin for my setup and found
griffin 8-70008-ls is same size specs as big rad for trucks but listed for car's with auto trans and gas motors. with 2.750 core thickness and 1.5" inlet and 1.75" outlet sizes .
griffin 8-70013-ls is same size specs as big rad for the trucks and speced for the truck with auto trans and gas motor . with core thickness of 3.00" and 1.25" inlet and 1 5/8" outlet size's .
gets you both hoses on pass side for cleaner install and trans cooler gets moved to left is only thing.
Old 09-21-2012, 11:16 PM
f6john's Avatar
Subscribed, I need all the info I can get.
Old 09-21-2012, 11:24 PM
green96ta's Avatar
I dont know why people keep buying all these adapters for the senders. You can use LSX factory senders to power the gauges, they work off of resistance just like the fbody gauges.....
Quick Reply: 84 chevy truck lsx swap parts list
