Need some advice. Defective LS2, need engine selection help.
GM reman LS2 long block $4300 local
Jasper reman $4750
Local rebuilt if block is still good. $?
I have been looking at Thompsons motorsports for a possible rebuild or replacement engine.
What would you do?
This is a street car only. Just for fun and crusing. Don't want to wild just peppy and that is why I choose the LS2 in the first place.
THanks
Jon
PSI
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Jasper reman $4750
What would you do?
THanks
Guess you found the problem! Any reason why you wouldn't keep your old heads? You could get a new forged & balanced shortblock from TSP or any of the other vendors here for under $4k...
I have no reason not to use the 243 LS2 heads. Once I take the engine apart we will see if I can identify the issue.
I am leaning towards buying a GM engine or a Thompson motorsports 6.0 with a cast iron block.
The benefit of the GM crate is then I don't need a dyno tune but I will sacrifice some added power that I was hoping to get.
I want a nice street/daily drive car, not a drag car.
