Post your 75-79 Nova LS swaps.
Old 07-10-2015, 01:48 PM
aknovaman's Avatar
Zackf2448 is that a yellow Vega in the background?
Old 07-10-2015, 01:50 PM
Zackf2448's Avatar
Yes it is a have 5. 2 hatches and 3 wagons
Old 07-10-2015, 04:14 PM
350SS's Avatar
https://ls1tech.com/forums/conversio...ket-build.html
Old 07-22-2015, 02:47 PM
ten5nova's Avatar
That's a sleeper from hell!! ^^^ Very nice!!
The following users liked this post:
Mery Jane (05-13-2020)
Old 07-22-2015, 02:52 PM
ten5nova's Avatar
This is how my heap looks these days, with a hood...
Old 07-22-2015, 06:53 PM
350SS's Avatar
thanks bud, we really wanted to keep the stock hood just for that reason. hopefully we'll still have enough of airflow to the motor with the setup
Old 01-17-2017, 09:00 PM
ItsNotaNova's Avatar
In the process of doing a Ls swap on my 78 Pontiac Phoenix (same subframe as a 78 nova) & was wondering which ebay shorty headers would fit my car?
Old 01-17-2017, 10:00 PM
76larkman's Avatar
Cool headers
these exit by bellhousing and fit mine quite well. There is a part on block casting u need to check for clearance. Header may not seal good against head if its touching header. Grind on it a little and it works
fit both mine. skylark and crewcab squarebody.
Old 01-18-2017, 07:23 AM
Do you have a link to the one's you bought?^^^^Thanks
Do you have a link to the one's you bought? Thanks
Old 01-19-2017, 02:18 AM
Montrose Patriot's Avatar
anyone done the LSx swap but retained A/C - im in possession of an unloved no respect malaise era 75 Nova coupe (original a 250/3 spd) which currently has a 305 and a THM350C in place of a grenaded 350 and a Muncie 4 speed (there r some tech articles on the T56 swap into an unloved 75-79 GM X platform since the drawback - no one reproduces the manual transmission swap parts (esp the manual clutch linkage which does NOT exist! incl the pedals)
Old 03-01-2017, 04:50 PM
  #32
cferensen614's Avatar
what oil pan did you use? how does it sit with the crossmember?
Old 03-01-2017, 05:38 PM
  #33
76larkman's Avatar
headers I used are just the china made that come up on ebay looking for Ls swap stuff. around $185 or so. Are decent pieces. I have muscle car pan and used adapter plates. I have it set forward far as can so my 4L65E barely clears tunnel in back where tailcone bolts on. If I take it out ever I'm going change or chop pan so not be lower than cross member. Chevy SSR truck upper radiator hose fits nice with truck pump. Dorman 300-130 steering pulley needed and change valve on steering pump out and lines work fine.
98-02 Camaro Ls radiator and fans
Old 03-01-2017, 09:52 PM
  #34
350SS's Avatar
nice
Old 05-22-2017, 12:02 PM
  #35
trobert3's Avatar
Default 78 nova
78 nova here been having car for 20 yrs, original 305 th350 trans, AC car. Drove 5 yrs with this setup, 2001 bought 350 crate rebuilt th350 installed auto meter indash gauges had 8.5 10 built eaton post better axles 3:50 gear.Drove for 5 yrs then it set for another 6 yrs. 2011 LS bug hit me,bought 09 Silverado drivetrain 5.3 with 6L80 trans, did VVT/DOD delete. ARP head bolts comp cams. Installed in car using Dirty Dingo Slider mounts, Holley 302-2 oil pan and pickup modified original trans cross member,made H cut in trans tunnel to fit trans used truck accessories and intake, stock radiator 2000 camaro e-fans under stock hood. Exhaust 2000 camaro long tubes, magnaflow X pipe,Borla mufflers 2.5 " pipe exit behind rear wheels.Speed Hut electric gauges in dash,new interior,original gas tank modified intank fuel pump great driver.
Old 05-22-2017, 01:45 PM
  #36
trobert3's Avatar
Old 10-15-2017, 05:07 AM
  #37
Default work in progress
have seen this in New Caney back in March 2017 - after viewing the video clip on YouTube with the Bonemaro (which is a trashed out 79 Camaro seen on Hot Rod Garage) would do the same with my derelict 75 Nova which has been sittin in the garage since 1997 - also the Goodguys show amended the cutoff year to 1997 where Malasians r now welcome...
Rev. Montrose Patriot (Z Crewe Houston brand ambassador)
Old 04-05-2020, 05:42 PM
  #38
Eric J Capenhurst's Avatar
Default 1975 4 Door Nova
I am still building my 75 4 door. I am in the reassembling phase. LS3/4l80e done, Texas stage 3 cam, 3200 stall, .660 duel valve springs, long tube monster. Interior complete, working on suspension now, and getting ready to vinyl wrap. Hopefully done real soon.
G Atsma (04-05-2020)
Old 11-14-2021, 10:55 AM
  #39
1977buickskylark's Avatar
what part number headers did you buy on ebay I'm building a 1977 buick skylark
Brydavis05 (11-07-2022)
Quick Reply: Post your 75-79 Nova LS swaps.
