what is the torgue for the stock rockers
Old 10-22-2012, 08:32 AM
Tramminc's Avatar
Default what is the torgue for the stock rockers
I loosed the rockers over a year ago to remove stress from the springs, I heard they should by torqued to 22 ft lbs.
is that correct and can it be done without putting the motor top dead center?
Old 10-22-2012, 09:35 AM
jmespe1's Avatar
AllData shows 22 ft lbs.
Turn the number one piston to top dead center of the compression stroke. In this position both of the cylinder number 1 rocker arms will be off lobe lift.
Tighten exhaust rockers on cylinders 1,2,7 and 8
Tighten intake rockers on cylinders 1,3,4, and 5
Rotate crankshaft 360 degrees
Tighten exhaust rockers on cylinders 3,4,5 and 6
Tighten intake rockers on cylinders 2,6,7 and 8
Old 10-22-2012, 09:38 AM
autogeek23's Avatar
thats what i did^^. called the TDC method.
Quick Reply: what is the torgue for the stock rockers
