Power Distribution
Thinking of getting this to wire the fans and fuel pump. I dont see why it couldnt work,
but checking to make sure I'm not missing anything. Thinking of using 20 amp fuses
http://www.ebay.com/itm/1-IN-3-OUT-B...f7230a&vxp=mtr
Lol....yea, I looked around, ending up buying the same type of block except it uses the newer MAXI fuses.
74,
I was thinking 30 amps for all three? Is that too much for the fuel pump and each fan?
I used the Painless Fuse Block setup. easy to use and expand.
http://www.summitracing.com/parts/PRF-70107/
Do you know OEM for the fans?
The 10amp powers term #85 on all three relays. The 40amp powers term 30 on relay #1 and #2 only. This would be for running the fan, the 10amp would be for the power for the relay switching.
I usually use a 30amp for the second one and have on blown it.
But, a lot of other have different setup, but fan power should also be based on the fan draw, how much amps it will draw, so the above are for stock OEM fans. Check with the many factor of the fans you are using.
BC
So much better. Avoid AGU glass fuses at all cost. Not only will you have a hard time finding anything under 40A (they are designed for audio amplifiers), the ends are glued on, then heated up to melt some solder to hold the filament in place. I replace 2-3 a month that have just fallen apart. Sometimes the loose connection happens on the inlet side, amperage goes up pre-fuse and they melt the fuse holder too.
Here is a photo I took at work last Monday. I keep them as examples why AGU fuses suck. Lol
If the wiring rating is unknown..I picked up an amperage meter from harbor freight ($8) that plugs into the fuse place. I can see the real amperage a part is pulling at full load, I typically round up to the closest fuse available.
Anyways I'm using 10 Ga wire with (GXL and SXL), I contacted Walbro, nothing over 20 amps is what they state....
I might go 20amps for all three.
BCzee, I ended up getting a MAXI fuse block. Basically the same size, just normal fuses.
10g will be more than enough. Glad you opted to not get AGU. It wouldn't be fun to have your fuel pump or fans drop out on ya over a crappy fuse design. Lol
