New use for truck mounts
Old 11-07-2012, 04:12 PM
MrPotatoeHead's Avatar
Default New use for truck mounts
Cut the strip of steel off the rubber, then remove the rubber. Presto you have a free start to custom mounts. Reading Denmah's threads got me all creative.
Old 11-07-2012, 04:27 PM
Stancel's Avatar
That is what I used on my swap into the IS300.
Old 11-08-2012, 01:56 AM
sawzall wielding director
G-Body's Avatar
I like the ideal but what do you use for a vibration isolator? The cleanest easiest thing I have found to do for mounts so far is to use mid 80` SBC frame side mounts (I always seem to be swapping on GM`s anyway) and then weld together an upper out of 1/4" plate.
Attached Thumbnails New use for truck mounts-hpim0926.jpg   New use for truck mounts-hpim0927.jpg   New use for truck mounts-hpim0928.jpg
Old 11-08-2012, 07:51 AM
gofastwclass's Avatar
I guess you could use the C5 Corvette type biscuit isolator - if you have the height.
Maybe I'm getting old (or wiser) but I don't like solid engine and transmission mounts anymore. Poly on the other hand is good stuff.
Old 11-08-2012, 10:06 AM
I'm a cheap *** DIY'er, so anything that I can use I do. I figure if you need a solid mount start these will definitly help, or use the hole in the center to use buiscuits or even hockey pucks.
Old 11-08-2012, 07:08 PM
I understand DIY, that's almost all I do.
Ages ago I saw how to make your own engine mounts. I'm not talking about the metal part, I mean the isolator. The article discussed making a mold and mixing your own polyurethane or something. The guy made a pair of mounts for some oddball car that was no longer in production.
Old 11-08-2012, 10:26 PM
i r teh noobz's Avatar
Could you measure the height of those? I can't seem to find my old truck mounts, but that may be the fix for my mounting issues.
Quick Reply: New use for truck mounts
