driveshaft? ???
Old 11-11-2012, 06:42 PM
zamora7's Avatar
Default driveshaft? ???
when doing an ls swap to any given vehicle they alll require a new or modified driveshaft correct. So my quesion is lets say i do an ls1-4l60e swap and later on decide to swap to a t56, do i need a new driveshaft?
Old 11-11-2012, 06:53 PM
i r teh noobz's Avatar
I would assume. The output shafts are likely to have a different spline count.
Try searching google for LS1 auto to manual conversions. Maybe someone will have a list of parts needed.
Old 11-11-2012, 07:08 PM
dlabooda's Avatar
LS1Tech 10 Year
The 4l60e and the T56 have the same spline count and the same length. You should be able to swap to a T56 with no issues other than maybe driveline angle (I'm not sure if the cross member mounts are in the same position)
Old 11-11-2012, 07:34 PM
chuckd71's Avatar
LS1Tech 10 Year
Would depend on what the t56 came out in some cases as well (I don't think cts-vs have slip yokes).
Old 11-11-2012, 07:51 PM
zamora7's Avatar
Thats what i figured provided its an fbody transmision. I can get a good deal froma bdduy for an ls auto setup. I can run thay until i can afford a t56.
Quick Reply: driveshaft? ???
