could i use this for a breather catch can?
http://www.jegs.com/i/Moroso/710/85406/10002/-1
would this work for a PCV breather catch can system?
I see people using ones like that but I don't know how they work with an open vent on them. If you want a catch can between the PCV and the intake manifold, then you don't want an open vent on it. Seems like that one would just suck air in through the air filter straight into manifold and not take a suction on the crankcase.
Also to be really effective you need some type of baffling inside the can to encourage the oil mist to condense into the bottom of the can. There is a really good thread on here about what makes a good catch can.
i've done quite a bit of searching.. can you post a link to that thread??
Having a filter at the catch can location will not work as most of the vacuum from the intake manifold will be drawn in at that point and will not go through the motor like it should.
