84c10 5.3/4l60e
84c10 5.3/4l60e
Well finally about to start my build. Found a 5.3/4l60e I've been lurking for awhile trying to gather all the info I can. Still needing info on what to do with trans cooler lines. I'm going to try and tackle the wiring harness myself I'm new to the ls motors so I will probably b asking a lot of questions
LS1Tech Sponsor
You will definitely love that vortec compared to that old 350! Ill be watching your thread! This swap is a fairly straight forward swap. The radiator from the newer trucks could very well be a straight swap. If not you can always just use an aftermarket trans cooler!
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
The connections on the trans look like a slip fit connection and I wasn't sure if I could use the same lines I have now or ill need new connections and lines. It's going to be a stock swap for now no kind of stall. I was wanting to use the stock radiator
Ordered some parts for the swap. 87 tank and sending unit, fuel lines and corvette filter regulator, lt schoenfeld headers, tac module. Hope all my parts come in by the time i get back in town. still needing the PCM and starter and alternator. Probably going to check the jy here in Lubbock before I go back
Ls1nova I read through your build its looking good I wish there was a jy close enough so I could go the budget route. I like the oil pressure idea might have to try it. Is the oil pressure not needed for the computer to work properly?? The orange and blue trucks are bad a$$ you do awesome work
LS1Tech Sponsor
You can either rework your harness (pictured) or purchase a standalone. Do you have the DBW components (Throttle body, TAC Module, TAC Harness, Pedal)? That may weigh into your decision due to cost.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
LS1Tech Sponsor
Ok. Do you have the TAC harness? Are you going to rework the engine harness in your picture above or buy new?
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
Yes I do have the tac harness off the pedal. All was needed was the tac module. Well I'm going to attempted it. Found lots of info just not sure about the splicing and soldering of the wires. If it doesn't turn out right I will probably order new. Just wanting to do it myself
LS1Tech Sponsor
Sounds good. Module is shipping today. If you have questions when you get it please let us know.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
