What all is needed from donor vehicle?
I bought a LQ4 and I have to take it out. I can get anything off the truck I need. I'm not gonna be using the trans cause I'm going th350. I know I need engine, accessories, and harness and pcm.
I guess I need data link connector too and gas pedal. What about fuse boxes under hood and under dash?
I would get as much as I could off the truck. Little bits and pieces will be needed as you go along, and if you dont need them, on sell them later. Nuts and bolts, brackets, hoses, as much wiring as you can get, fuse and relay boxes also.
I bought a whole wrecked car to do my conversion, and it was surprising what I used.
This question gets asked a few time every year.. If search is used correctly, you will find a those Threads..
Donor LS1 Advice / Inspection & refresh
Need donor vehicle advice
Donor truck or parts?
Donor 2003 tahoe
What should I take from donor car fbody swap
Good Luck with the reading..
BC
Donor 2003 tahoe
BC
