Fuel System
Fuel System
Need help ordering a fuel system from pump to injector:
I have a L92 converted to LS3 and planning a small street twin turbo setup for approx 650rwhp/tq without worry of fuel starvation during occasional autocross practice.
Fuel Pump-considering the following:
-aeromotive phantom in stock tank- http://aeromotiveinc.com/2012/11/phantom-fuel-system/
-Tanks Inc-in stock tank- http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm
-Tanks Inc- new FI tank with baffle and in-tank pump- http://www.tanksinc.com/index.cfm/pa...rod/prd378.htm
For Filter/regulator- I'm considering a stock corvette unit?
I also need help figuring out what fittings, what size supply/return lines, what filters, regulator, and what injectors that I will need for my goals.
I'd really like to hear from anyone with personal experience with the above options or anyone that has succesfully achieved the same goals.
Thanks in advance for any help.
None of that will work if you truly are going to make 650hp at the wheels. The 340 pump is only good to 700hp and you'll be way over that at the motor. Even if you plan that at the motor it'll be stressing the pump and lead to early failure. You'll probably need the A1000 inline pump with -8 line sumped into tank. And look for atleast 65lb injectors
WTF is a small street turbo setup lol?
Sorry don't have any experience with that much power, I would imagine a dual pump setup would be your best bet.
I don't think that regulator will work and you will probably need an adjustable one for the turbo deal
Have you taken a look at a Rick's VaporWorx tank w/CTS-V module? I have pretty much the same hp/tq goals as you do and picked up the Rick's tank. Using 3/8" stainless hardline, no need for a return, still mulling over what fittings to use but will most likely go Swagelok with PTFE hose off the hardline.
Meaning I haven't purchased turbo components, yet. But I know they will be small (58-62mm) twins.
The regulator was the one thing I thought I had right .... many vette guys run their stock filter/regulator at least I believe. I will look into boost referenced regulators though, thanks.
Maybe try to be a contributor or stay out of the damn thread. Thanks for you valuable input though.
Maybe fuel slosh is a problem better related to old cars with old tanks with no baffling that would be better understood in the conversion forum...just a thought.
Thanks I'll check it out, but I was hoping for an intank setup using my current tank.
I'm wondering if I could use then Tanks Inc In-tank system with the tray and order either a second walbro 255 to mock into the tray for a duel pump setup....or order the 400lbh pump they offer. Good Ideas?
I have a PA4.. I can tell you, it might be a restriction on flow.. as the threaded ports are drilled and tapped for 1/4" NPT fittings... which is not a very big opening.. 3/8" opening on the fitting and hose.. so .. if you expecting to go -8 or 1/2"... them opening are the restriction. You would need to redrill them bigger and rethread them for -8 or the next NPT threaded fittings.
Yeah.. you might be able to use double pumps and I would also recommend going with a aftermarket Regulator.
You should see what I did on my Nova tank to use the PA4 and sumping the tank. follow my link in my sig..
BC
BC
