Ls3 swap what trans
Dont give out info if you dont know the answer.
Yes, you absolutely can run a 4l60e behind that. Obviously your engine harness needs to be either modified or have a custom harness made for your application.
FOR EXAMPLE If you get an F-Body harness and you decide to modify it to fit, you'll need certain engine extensions and conversion harnesses since the LS3 has a different location for Knock Sensors, Cam Sensor & MAP Sensor.
Your best bet is getting a custom harness made from one of our sponsors. Much easier than dealing with the headache of making sure your harness is perfect. Working with the electrical part of a car can be a royal PITA if you don't have the proper resources
