Wiring In A/C Recognition Circuit
Old 05-08-2013, 07:22 PM
jeeperanthony's Avatar
Default Wiring In A/C Recognition Circuit
What do I need to do to get the idle to bump when I turn the A/C on? There's a pin on the PCM for A/C request, and A/C signal.(on the red connector).
Do I run 12v to the A/C status pin, or something else? Is it even all that important for the idle to bump up?
Old 05-08-2013, 10:01 PM
ls1nova71's Avatar
It's really not all that important, the PCM will see a drop in rpm when the compressor kicks in and compensate for it with the IAC. Some people say just hooking 12 volts to the A/C request will bump the idle, but I've never tried it. If you want the PCM to control the compressor, you'll need the pressure sensors that go along with it.
Quick Reply: Wiring In A/C Recognition Circuit
