95 v6 camaro 5.3 swap
so i was given a 5.3 vortec complete motor with harness and ecu from a yukon i believe. and i picked up a 95 v6 for $450 bucks. so i want to put it in my car and end up turboing it but that will come after its in and running. i plan using t56 but the 4l60 seems easier to find and much cheaper. my question is wiring and what i need to wire it properly. i know i need ls1 steering oil and intake. also what cam will runn decent n/a and work with a 10-12 psi turbo setup later. i want to run ls6 intake and the head from the 5.3 with new spring and valves. any help is good help thanks.
you will ahev to change the front fuse block harness to have 2 inj fuses and you will need a ls harness for eng and dash , and a k member for ls car , radiator for v8 car , radiator will have an extra nipple under the cap on the pass side , you will need a v8 tans crossmember and a driveshaft due to yours is a 2 peice shaft
