anyone used Exhaust Manifolds on a Mustang?
Old 05-21-2013, 09:40 AM
streetknight2's Avatar
Default anyone used Exhaust Manifolds on a Mustang?
I've got dynatech swap headers on my Mustang, but putting a stock motor in my Fairmont for a driver. I tried truck manifolds and that's not gonna work.
Anyone found any that will work?
Old 05-21-2013, 09:57 AM
jfisher's Avatar
I've seen some use the 2010+ Camaro manifolds, but you'll have to get a different steering shaft as the stock rag joint will interfere.
I plan on running 351w swap headers and massaging the tubes and having LS flanges welded on.
Old 05-21-2013, 10:01 AM
I tried the 351 headers on this car already. Talk about a nightmare. It may work with some transmissions, but with my TH350 not gonna happen. Not only were the # 5&7 tubes gonna have to be moved but the collector was right against the transmission pan. Lot of tweaking to be done.
Old 05-21-2013, 04:16 PM
tired2valve's Avatar
im using the 2010 camaro ss headers and they fit great on my 99 mustang, only had to clearance the drivers side flange a bit cause it rubbed on my steering shaft.. still does too on max right lol i need to pull that side and clearance it some more i did it when it was in the car and could hardly get the grinder in there
Old 05-21-2013, 04:59 PM
booboo37's Avatar
Try g8 ......if they both dump near the fire wall then they will work but now you need flanges................i think those are the ones i tried on my 93 notchback..........or heres some cheapy headers........
http://www.jegs.com/i/Hedman-Husler/...ductId=2167916
Old 05-22-2013, 08:35 PM
boostnut's Avatar
Gen 5 camaro fit like a glove. No clearance issues for me, I'm running an aje k-member fwiw.
Quick Reply: anyone used Exhaust Manifolds on a Mustang?
