shifter question 70 camaro ls2 with 4l60e
will my existing stock shifter work with the combo im about to drop into my camaro. had a 700r4 going with 4l60e, also will my existing crossmember work?
I had a 350/700r4 combo in my 77 before, when i put my 5.3/4l60e in i had to move the crossmember back a few inches and also had to cut the mount and locate it lower on the crossmember so my drive shaft/tail shaft had good clearance.
IIRC the mount point on the 4l60e is further back than the 700r4
The rear isolator mounting pad is located in the case on a 700R4 just behind the pan and was relocated to the extension housing in the design of the
4L60/4L65/4L70/4L75 transmissions, so they are not the same.
