My track/street 240sx LS Swap
Old 06-12-2013, 10:47 AM
BoostinIx's Avatar
Lookin good!
Old 06-12-2013, 11:53 AM
00-BUCK's Avatar
sweet
Old 06-12-2013, 11:55 AM
curbcheck's Avatar
man, i really wish i had a shop like that to work out of
Old 06-12-2013, 12:08 PM
ramairetransam's Avatar
very nice build
Old 06-12-2013, 01:39 PM
cosmo22nov's Avatar
So I know you hear about 240's getting sideways all the time but hows this for sideways haha
Repairing that nasty rust hole where the battery tray once was. And I know my welds aren't pretty. This is pretty much the first time I've ever welded.
And there was a bunch of very small rust spots in the truck so I got that all patched up with some fiberglass.
And the pile pf engine parts just keeps getting bigger and bigger...
Old 06-12-2013, 01:44 PM
cosmo22nov's Avatar
Well my dad and I decided to turn one of the horse stalls into a small paint booth for parts since it wasn't being used. Plus we had to try out the new paint gun.
I got the crossmember and front spindles coated in some epoxy primer.
And then I hit them with some extreme chassis gloss black from eastwood
Old 06-12-2013, 07:02 PM
brewster240's Avatar
Originally Posted by cosmo22nov
I am using a later year Q45 diff (97-01) so I wouldn't have to source a twin turbo 300zx axle shaft. The later year diffs can be used with 92-94 j30 axles. I have a 98 q45 diff and 93 j30 axles.
http://www.ka24development.com/vlsd.html
well than you arent using the parts that make it any stronger lol.
the gear ratio is a bit better for a 6spd/ls setup though, so you have that i guess.
Old 06-12-2013, 09:06 PM
LQ4-E39's Avatar
great build! love the coupe chassis compared to the hatch. subscribed.
Old 06-12-2013, 09:37 PM
cosmo22nov's Avatar
The diff itself is still stronger than the stock 240 unit. And I doubt I'm going to break an axle shaft at my power levels anyways. Plus I had an open diff and needed an LSD option. I picked up the diff and axles for $150.
And thanks LQ4-E39, I prefer the coupe myself. I have a friend in the process of an E36 v8 swap right now. It should be pretty cool. Although it is a 5.0 mustang motor....
Old 06-12-2013, 09:47 PM
its not though. the diff doesnt break. the out put shafts break, and the cvs break.
vlsd are also not good for much. once they get hot they dont work. put a lot of power through them, they dont work.
if youre not worried about strong axles, your best bet is getting a kaaz or similar for the open diff.
rest of the build looks good!!
Old 06-12-2013, 10:03 PM
cosmo22nov's Avatar
Well thanks for the compliment. I guess I'll toss it in and see how it does. If I break it down the road I'll just get an earlier q45 diff. I don't really feel like dropping the money on a kaaz.
Old 06-13-2013, 12:01 AM
  #32
69face's Avatar
best frame (subframe) off resto ever. looks great!!!
Old 06-13-2013, 06:00 AM
  #33
BoostinIx's Avatar
What I'd give to have mine go on the rotisserie and get cleaned up like that...lol. Awesome man.
Old 06-13-2013, 08:45 AM
  #34
cosmo22nov's Avatar
Here is the dual pass low profile radiator from chase bays. I wanted room for an intake setup up front instead of to the side like most swaps. And the fans are rated at 1750 cfm a piece.
The place that did the sand blasting for the body was a little aggressive on some of the panels and warped them a little. So my dad and I are working on getting those smoothed out. I also shaved the are were the antenna was. And there were a couple dings that needed worked out anyway.
Smoothing out where I patched the battery tray area.
Old 06-13-2013, 08:46 AM
  #35
cosmo22nov's Avatar
And there you have it. All caught up to how the car currently sits now. Still lots of stuff left to do.
Old 06-13-2013, 08:41 PM
  #36
rotor vs. piston's Avatar
Always lots to do
Old 06-13-2013, 10:10 PM
  #37
dvdswan's Avatar
tell me more about this radiator. HxWxD with and without fans, I'm still looking for a rad for my truck
Old 06-14-2013, 05:45 AM
  #38
BoostinIx's Avatar
http://www.chasebays.com/brands/chas...minum-radiator
Old 06-14-2013, 09:18 AM
  #39
dvdswan's Avatar
nice. thank you.
Old 06-15-2013, 04:25 AM
  #40
sierrac3_s2000's Avatar
I would be very surprised if that radiator provides enough cooling for your engine. Maybe since you are up north where its cooler it won't be so bad. My S14 with a full size dual pass radiator always had heat soak issues while sitting in traffic. With only 750cfm per fan you won't be moving much air either. I had dual 12" 1250cfm fans and I still didn't pull enough air across the larger radiator while idling.
Quick Reply: My track/street 240sx LS Swap
