for thos e of you with fox bodys and MT ET street pros...
Old 09-09-2013, 09:19 PM
LILHEMI's Avatar
Default for thos e of you with fox bodys and MT ET street pros...
what are you doing to get them to fit? i got mine in and ive hammered the dogshit out of the inner fender and rolled the fenders almost flat and the drivers side is still rubbing just a tad. i have 2mm spacers on them to give me just a hair more clearance on the inside. i have stock v8 springs with a coil cut off per dave at teamz. it does sit a little low in front. would bringing the front up help with rubbing in the rear?
Old 09-09-2013, 09:33 PM
gm-ntmr's Avatar
15x10 6in back space
What's your wheel setup and width on rear end
Old 09-09-2013, 09:44 PM
LILHEMI's Avatar
15x10 6.5" backspace stock width rear.
Old 09-09-2013, 10:00 PM
gm-ntmr's Avatar
I would think it would be easier to lose the spacers and massage the inner it should clear fairly easy
Old 09-10-2013, 10:09 AM
LS1PUNK's Avatar
Is the rear centered?
Quick Reply: for thos e of you with fox bodys and MT ET street pros...
