mating a 2002 5.3 ls to t5 camaro
i have a 5.3 ls 2002 silverado.. want to hook up to to around a 1996 camaro t5...wondering what flywheel clutch i should get.. any suggestions..should i use the sachs flywheel? or? stock ls1....any suggestions?
x2... A WC T5 has a 300ft/lb max rating. Not only that, they grenade behind 6cyl's and 305's... Your better getting rid of the T5 and finding a T56 to put behind it.
If you are going do it, you picked the the wrong T5. The one you need is one from a 3rd Gen F Body one that was behind 5.0 V8 not a V6. The problem with the Gen IV V6 T5 it has a Ford style case its not strong enough and a hassle to match a bell with it. The 3rd Gen V8 T5 has a GM muncie patten . Then get BBC #621 bellhousing and a LS1 flywheel and clutch kit.
Yes you can. T5's works fine with LS as long as you don't put slicks on it. Modern driveline makes an adapter to fit a foxbody T5 with Chevy big block bell housing for LS. I will be putting an LS 5.3 or 4.8 which I already have with a T5 in SN95 Mustang.
Here you go!
https://ls1tech.com/forums/manual-tr...-can-here.html
Here you go!
Here you go!
Here you go!
