67 Chevelle - LS7, T56 & Schwartz Chassis
Old 01-21-2014, 06:52 AM
fxdlryan's Avatar
Originally Posted by jamier2
Very nice. I have a question about the lights.
You said you now have 4 hi and 4 lo beams. Do they have two high and low per bulb? I may look into swapping my 66 lights, but I would do all 4 bulbs. Would I end up with 8 hi and 8 lo beams? May be interesting.
Thanks for the ideas and great build. I can't wait to get mine back from alignment so I can get it on the road a little. May even steal your color. I was thinking Maximum Steel 2014 Jeep color but not really sure. Your outside pic looks very nice and dark, almost a black chrome, but inside pics look much lighter. Which is more accurate to how it "really" looks?
4 Lo and 4 Hi was before removing the inner headlights. If you're doing all 4 bulbs you can wire it however you want for 4 lo 4 hi, 2 lo 2 high, 2 lo 4 Hi etc. JW Speaker produces the headlights for Harley, they also produce specific muscle car headlights in 2 Lo 2 Hi configuration, but they are substantially more expensive. Ironworks Speed and Custom sells them: http://www.ironworksspeedandkustom.c...rod/prd106.htm
The color is difficult to explain, in painter terms it has good flop, it flops between lighter gray to almost black depending on angle and lighting. Swing by any BMW dealership and look at a car in Mineral Grey Metallic and you'll get a better idea of the color. I chose the BMW variant of the color because of the much finer metallic and it never has a purple or pink hue like the Ford, Dodge and others that are similar. Mine is a straight PPG mix of the 2013 BMW Mineral Grey Metallic.
Old 01-21-2014, 08:02 AM
jamier2's Avatar
Awesome. Thanks.
Old 01-22-2014, 03:13 PM
ijimmy's Avatar
$1,200 for 2 bulbs is kind of high
Old 01-30-2014, 06:16 PM
fxdlryan's Avatar
Lots of progress in the last few weeks. After some heavy modification for the rear sway bar mounts, the Ricks tank with CTS-V pumps is in:
Switched over to a hand operated emergency brake and everything is hooked up and working:
Got a nice mount for the Vintage Air controls fabricated:
Fire suppression bottle mounted and nozzles placed:
Old 01-30-2014, 07:30 PM
jamier2's Avatar
Which E-brake handle did you use? Any reason cables have to be routed over tunnel? Looking awesome man.
Old 01-30-2014, 10:28 PM
fxdlryan's Avatar
The cables had to be routed over the trans tunnel because there wasn't enough room under the tunnel. Since I won't have a back seat, it was no issue going over the tunnel because I'll just continue the console all the way back.
Old 01-31-2014, 05:22 PM
jamier2's Avatar
Thanks. It looks like the Lokar handle, is that right? How solid does it feel?
Old 01-31-2014, 07:55 PM
fxdlryan's Avatar
Sorry, I missed the question originally, yes it is a Lokar and it is rock solid with the base we built. The Willwood adapters didn't work quite as advertised, but it's a really nice solid setup.
Old 01-31-2014, 08:35 PM
novaskilling's Avatar
Default Reservoir and intake
Beautiful car, where did you get the power steering reservoir and cold air intake? Do you have part numbers? Cheers.
Old 01-31-2014, 08:39 PM
427zm's Avatar
Beautiful setup, with great power!
Old 02-01-2014, 05:21 AM
fxdlryan's Avatar
Thanks for the compliment.
The power steering reservoir is from Detroit Speed, P/N: 090601http://detroitspeed.com/Steering/090...reservoir.html
The Cold Air Intake is from Spectre Performance, PN 901108
http://www.spectreperformance.com/se...px?prod=901108
Old 02-01-2014, 05:22 AM
  #32
fxdlryan's Avatar
Thanks.
Old 02-09-2014, 01:36 PM
  #33
fxdlryan's Avatar
Fire Suppression Activation Button mounted in the Ashtray:
I got all of the spots on the chassis touched up from exhaust fabrication and frame notching, I got the shock tower brace painted and the remote reservoirs for the coilovers mounted:
I got the fuel vent and differential vent installed but need some more AN fittings to get them plumbed:
My daughter was less than impressed with having to ride up the lift in the trunk for the process:
Old 02-09-2014, 04:24 PM
  #34
1989GTA's Avatar
Very nice. I like how you did your cold air intake.
Old 02-09-2014, 06:30 PM
  #35
fxdlryan's Avatar
Thanks
Old 02-17-2014, 05:45 PM
  #36
68BBChevelle's Avatar
Super awesome car man. I just got me the spectre cold air intake too. But think they sent me the wrong heat sheild. Could you post few more pics on how yours is attached? Thanks alot.
Old 02-18-2014, 05:02 AM
  #37
fxdlryan's Avatar
I think I have some pictures still in the camera, if not I'll try to get out to the garage tonight and take a couple of pictures for you.
I ended up having to trim that piece a fair amount to make it work and cut a relief for the outer fender lip, I also ended up having to weld tabs on the edge under the radiator because my radiator was wider and deeper than stock. Then we didn't like how close the intake tube was to the fans, so we ended up cleaning up the pipe and doing away with the rubber elbow. I can't blame Spectre though because my radiator and chassis are non-stock as well as have replacement fenders. It probably would have been cheaper and faster to just fabricate it from scratch,
Old 02-18-2014, 05:28 PM
  #38
jerrad's Avatar
What a killer car. My dad had a 67SS and sold it when my older sister was born, he still regrets it 33 years later. lol
Old 02-22-2014, 01:56 PM
  #39
UZI67ELCO's Avatar
Originally Posted by fxdlryan
the 3 inch exhaust is in with borla xr1 mufflers. We ended up deleting the inner portion of one of the cross members to make for a cleaner exhaust. There's roll bar almost directly above this location so i don't think we've lost any structural rigidity over the standard schwartz chassis:
the aerocatch hood pins are in and the air funnels replacing the inner headlights are all buttoned up:
a detailed shot of the brackets underneath for the hood pins, below this bracket is the remote oil filter and air cooler:
the drysump tank is in:
the oil cooler and remote oil filter:
remote power steering reservoir:
plates in the trunk to get the remote reservoirs thru the trunk floor:
a shot of the driver's side showing the exhaust:
where di you get that support brace?
Old 02-22-2014, 05:18 PM
  #40
Tramminc's Avatar
[/QUOTE]
What is that tire sizes?
model, offset and size of wheels?
What spring weight did you use in the front?
Quick Reply: 67 Chevelle - LS7, T56 & Schwartz Chassis
