5.3 s475 foxbody, with A/C and holley efi.
#307
Truth be told, even when I had the full exhaust on it, I never closed the dump, it was never that loud in the car.
Why don't you go get T Boned again or something.
#309
Did you sell your single turbo set up?I'm trying to find one but all I've realy found is on3performance ones and cx but not sure about them and I realy like how you had your dump pipe or exhaust.And do you have any other parts to get rid of I'm just getting started on mine
#310
I got some stuff I'll put up for sale. That bad *** T6 merge I just bought, T6 heat blanket, both 38mm tial gates as I'm switching over to 44s.... think that's about it.
Clean looking set up you got so far.
#313
Got the call to go pick the car up, so I flew over and picked it up. Guy did an amazing job despite the wait. As soon as I got it off the trailer, I put it on jack stands, pulled the front end off, mounted the turbos, and started fabbing the headers. The car is so damn light in the front now, even after changing over to 175 springs in the front, they don't even compress. So looks like I'll have to put the 150s back in it.
That rear tire tuck tho... got about 3" from the inside of the tire to the wheel well. I'll be looking in to a set of deeper offset wheels here soon so suck the wheels in a bit more so I can stuff a bigger tire back there.
#319
Other then that, I got the one almost fully welded out. I don't think it's bad for my first header and only welding maybe 2 months.
#320
Made some more progress. Charge pipes are done, driver side header is about done, just gotta finish welding one runner. Also finished the header to turbo pipe. I need to put the fender on so I can see how much room I got to play with in regards to positioning the wastegate. Passenger side header has one runner complete, but ran out of material. But otherwise coming along very nicely.
