Fuel Pump for Ls1 swap in 91 C1500?
getting ready to swap the engine and wondering what fuel pump i have to use? and what mods i have to do to make it work? Also how do i make my stock fuel lines work with the ls1 fuel rail? thanks!
I don't get why everyone talks about the corvette filter regulator when there is a regulator right on the stock fuel rail??
Get a high pressure pump (60+PSI) and install it in your tank. A pump outside the tank will have you terrified of a dentist for years because of the whine.. There are companies that offer AN fittings that go onto the stock rails to make fuel line selection easier. I have a pair of -6AN fittings but haven't bought the line for them yet.
If you are going to put aftermarket lines on this later on, change that to doing it while the engine is out of the engine bay so you can route them and secure them easier. Measure twice, then one more time, then cut once, about a foot too long!! LOL
Take your time and do a TON of research...
^^^this. He ain't lying. My truck came with an external and I can hear it from my third floor apt when it's warming up in the morning over the glass packs. Literally the worst way you can spend money other than on a mustang. But I have two tanks so it's better than buying two Waldron I guess. Your rail will have a regulator on it but you will need to run two lines. You'd an use your stock lines also. I used 6 AN lines and an Earl's rail adapter. I used a corvette filter bc I am using an F body intake/rail.
BC
