My 91 C1500 LS1 Swap thread.
Thanks, and nice ill eventually build a 370 lol. And not yet i Heard it should work with the 99-06 alternator/power steering bracket ill try to install it this weekend. And yea they are a pain in the *** but there is 1 bolt that is hard to get to. Tomorrow when i get home ill post a picture of what i used to get to the nuts and how i got to them.
Thanks I would appreciate it. Here is a link to my build I haven't really gotten into the swap part of it just the engine building. https://ls1tech.com/forums/carburete...-370-swap.html
I will probably have a few more questions for you before I'm done haha
These are the passenger side nuts a lil less space than the drivers side as you can see.
And these are the driver nuts, more space and easier to see the nuts. This side is the easy side shouldn't take that much.
Well today is a sad day. I tried getting flywheel bolts here locally and noone had them. So i am going to order the flywheel bolts and pressure plate bolts this Monday. Hopefully they get here soon.
I swapped in a 5.3 into my k1500 and we used my stock 350 pressure and return lines with the 2003 5.3 . Just had to do some bending and it for and has worked well since. Hope that. Helps you guys out.
Yea that's what I'm using...and i have a ls1 intake but thanks for the help!
Did you have the headers on before you put the bolts through the clamshells? If you leave the headers off until after the bolts are easy to get in, even with 1" setback plates. I've done 4 obs swaps and never had to spend more than a few minutes on those bolts, and the Shoenfelds will go on after the engine's in place. So will shorties and stock manifolds. Nice build by the way, I'm doing a 92 sport right now, LM7/4l60e swap.
#33
#35
Well, just ordered arp pressure plate bolts and chevy performance flywheel bolts. Arp bolts get here the 16th and the flywheel bolts don't ship til the 17th, just my luck. Well that isn't going to stop me, going to do my fuel setup and clean up the engine bay this weekend.
#37
Great looking swap, My friend is in a search for a 90s single cab to swap out his ls1 and 4l60 out of his Camaro soon. This will help us out when the time comes, Thanks
#38
The lines from your 1992 truck work with the ls power steering pump.
#39
