Need wiring help for this CS130 alt and CS130D wiring.
Old 02-16-2014, 01:51 AM
FIRECHICKEN5.3's Avatar
Default Need wiring help for this CS130 alt and CS130D wiring.
Ok so I have a 5.3 truck harness with the wiring for the stock CS130D alternator. Only problem is that I need more room and I will be running a CS130 alternator from an 89 Trans Am. Smaller case. Now I'd like to just use the factory stock CS130D wiring to control the older alt. is this possible? I think both wires for the truck alt go directly to the computer but the trans am alt wires don't I believe. I have seen an adapter made by powerhouse to convert or adapt between the two and I would like to use this incase I have to change back to the truck alt.
Any ideas guys??
Old 02-17-2014, 06:17 AM
zamora7's Avatar
Check bp automotive, car shop, Casper electronics, Ron Francis wiring to name a few
Quick Reply: Need wiring help for this CS130 alt and CS130D wiring.
