LQ9 w/2000 Camaro Radiator - Which Rad Cap?
Old 03-17-2014, 11:45 PM
sprech's Avatar
Default LQ9 w/2000 Camaro Radiator - Which Rad Cap?
So, I'm ordering the radiator, fans and gas tank for the Firebird and was about to order the cap and it occurred to me, which cap do I order.
The LQ9 is from a 2004 Silverado SS which calls for a 15 lb psi cap
The 2000 Camaro calls for an 18 lb psi cap.
My thought is to go with the 15 lb psi cap, because the LQ9 may not be able to handle the constant 18 lb psi?
So the question is, will a 15lb cap fit into the 2000 Camaro radiator?
Quick Reply: LQ9 w/2000 Camaro Radiator - Which Rad Cap?
