68 Camaro LS3 - Which Radiator?
I'm in the beginning stages of a LS swap into a 68 Camaro with an LS3 and T56 and I'm not seeing a lot of choices in radiator/fan combos. I searched to see what everyone is using and I can only come up with two.
Ron Davis - no idea how much
Griffin - CU-00009-LS $650
Are there any other brands I'm missing that are similar to these and hopefully a little less.
TIA.
TIA.
TIA.
TIA.
The Camaro is a much smaller car so I doubt the GTO radiator would fit...but if it were me, I would try to find a stock one. Lots of guys run only aluminum though....choice is up to you.
http://www.ebay.com/itm/Heavy-Duty-Extreme-Cooling-Chevy-Gm-Aluminum-Radiator-19-31-3-Chevy-Sbc-Bbc-/191059063006?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c7c01f0de&vxp=mtr just find one in your measurements .. i wouldnt pay anything over 200 bucks.. im cheepo .. And to really get cheap i went to junkyard , pulled a v6 camaro 98' radiator with the fans for $50 bucks , never had problem over heating ..
Check out Superior radiators in mt.Clemens mi. They have direct fit ls radiators. all aluminum welded construction. Both inlet and outlet on passenger side and also includes a nipple for a steam vent. radiators are like $350 + $250 for dual fans
I got a universal fit aluminum radiator from Summit for $169. I forget the measurments of the radiator, but its a two row. I took some scrap aluminum and make four 90 degree brackets and had my welding shop weld them on the tanks. Drilled a few holes and it fits great. I got a universal electric fan and fabed up a mount so it sits inside the stock fan shroud. I have had this setup in the car since 2008 and have not had any issues.
