wideband threw a/c or other wire
I am putting a 05 5.3 in my 55 chevy using a stripped down stock harness with a/c rear 02's and evap removed. I am using hptuners standard to tune with so I want to put my wide band threw the ecm. Is the green connector #14 RED/BLK A/C Refrigerant Pressure Sensor Signal wire to my output of the wide band the only wire I need to leave to read my wideband signal? Or is there a better choice like downstream 02 wires since they will already be long enough not sure if they accept a 5v referance or not?
http://api.viglink.com/api/click?for...nd-through-EGR
http://api.viglink.com/api/click?for...Manual_1.1.pdf
Found this by searching forced induction section.
