blow thru or fuel inject 370 76mm build
ok guys im a lil closer to putting my car together. just a street ride found some good deals on some parts and now im at a crossroads..
370 forged rotating assembly use the 317 heads or the l92 heads i have both
carb and do a blow thru set up or switch to fi. if switching to fi what ecu, intake tb and fuel system would be good for me thinking of maybe a victor jr style intake and elbow w tb billet rails... idk
also what ecu, going to a shop in nc for tuning and i believe they use hp tuners i have heard the 0411 ecu is ok and was thinking of just having a stand alone harness made looking for around 700 whp +/- my goal is to hava a street car first, race car second.
was doing a nitrous set up but have bought a complete turbo kit now so plans have changed turbo 350 trans
car suspension and cage are done
ok, update
0411 ecu, custom harness going fuel injection
speed density tuned with hp tuners
so, use the 317 heads or the l92 heads
think i pretty much have the rest figured out
thanks
external inline pump and filter, boost ref regulator, -10 feed to reg, -8 to fuel rails, -8 return to tank
ls7 lifters,arp head studs, ls9 head gaskets, custom turbo cam
if i use the 317 heads intake selection will be easier, using the l92 heads should yeild a bit more power what you guys think
thanks
