Which pulley ?
Which pulley ?
Running truck accessories on my LS swap in my A-body. What power steering pulley are you guys using ? The factory pulley hits the power steering pump, I saw dirty dingo sells one, is there an over the counter alternative. Thanks I've searched but can't find an answer.
I have been battling this issue for the last couple of months. Dirty Dingo sells a machined version of Dorman 300-123. You don't need the machined version if you space the pump back approx an inch.
Personally that is what I am running at the moment. However, I have been looking for an alternative since 300-123 is a plastic pulley and my first one exploded at about 6500rpm. I recently picked up 300-130 which is basically the same except it's made of metal and has a larger diameter (5.78") I think it will fit on my car but I haven't tried it yet.
