New Hooker G-Body LS Swap System Preview
#561
If you can send me a PM with your phone number I'll have someone in Tech Service contact you if you want to swap it out. If you don't want to bother going through that process then you can just bend the rod towards the rear of the car and see if you can achieve alignment without replacing the hanger.
#563
1" setback mounts plus hooker headers = success on my buid. Check it out here:
https://ls1tech.com/forums/conversions-hybrids/1795862-gbody-5-3l-lsa-blown-conversion-holley-swap-kit-address-your-questions-thread.html#post18902090
Thanks
Dave
Thanks
Dave
#564
How does the ceramic coating hold up on the hooker headers? I guess I'm wondering how good the quality of it is, I know some ceramic coating is better then others. The ceramic coated headers fit my budget better then the stainless, and my car gets less then 1k miles a year.
#565
#566
problems with el camino exhaust
I've been following this thread and pulled the trigger and purchased the stainless 2.5 exhaust for my 1983 el camino thru summitt. It took about 2 weeks to finally get to my house. I purchased this system so that in the future I could just buy the headers cross member and motor mounts for a LS swap down the road.
Currently I have a 350 with proflo edelbrock efi 13 yrs old. It still runs great just some maintenence issues. So in the down time waiting for the exhaust to show up I pulled the motor and resealed the intake, timing cover, pan etc and sent the injectors to be cleaned etc.
So I put the motor back in yesterday and started on the exhaust today and its about 12" short so I'm thinking my el camino must be longer than the monte carlo etc. I noticed holleys El Camino Verde had the mufflers forward from were this new setup is to compensate for the difference maybe? Just wanted to post in case someone else was thinking about this for their el camino.
The exhaust looks amazing, mufflers are nicely tig welded and awesome factory style hangers just wished it fit. Going to contact hooley/hooker tomorrow and see what can be done.
#567
#569
Has anyone else had issue with driver side header being too high for exhaust pipe to fit though hump in cross member to align properly? Passenger side is dead on . Driver’s side is ½ in to ¾ off form being dead center of header.. Motor is perfectly level in car and everything else seems to be dead on.. Only issue I have found so far (beside coil hit A/C box on install..lol .Good clearance after engine was in ). Car is 80 Malibu with LQ9.. Started the car the other day and runs perfect exhaust was only project left..Figures right ..lol
#571
#572
This winter I plan on switching from my 1" setback plates and f-body headers to the hooker mounts and headers. I apologize if this has already been covered but I didn't see it just skimming this thread. Has anyone used the hooker engine side mounts with solid mounts? I Currently have these mounts that are the same as stock clamshell dimensions and would like to stick with them. Any reason they shouldn't work?
#573
#574
The alignment disparity between the driver side header collector and the crossmember is accomodated by the incorporation of a drop section in the left inlet tube of the Hooker exhaust system. If you are going to use another type of exhaust, you'll need to fabricate something similar.
#575
.Just to make sure I have the Z bracket (12647HKR) frame adapter kit installed right ..Was the intention for this z bracket to sit on top of lower frame rail or to be bolted on bottom side? Just want to make sure I'm not losing anything there.. Thanks as the instructions never really said..
Thanks
#576
The Z-bracket does indeed get attached on top of the bottom frame rail...the proper configuration of the crossmember assembly with the Z-bracket attached to it will look like this...
#578
First post and quick question, I don't recall seeing it asked in the thread. I have a column shifter and bench seats in my '86 Monte Carlo SS. Will the headers interfere with the shift mechanism? I have a stock 305/200R4 and will be using a 4L65E behind a LS3. I like the old school look of a shifter on the tree. Thanks for a very educational thread.
#579
#580
In a G body this shouldn't make a difference. Both set ups use the column interlock linkage required for key lock, neutral safety and reverse lights. Whether the car is a floor shift or not does not change said linkage geometry. GM used the same set up for both versions.
