ford 8.8 yoke for gm u-joint
You are going to need to figure out which yoke or companion flange you have on the 8.8 by measuring it and researching some of the custom driveshaft mfg websites.
If you're using an 8.8 (car) it likely will use a 1330 Ford or 2-4800 u joint which is 3.622" wide and has 1 1/16" cap diameter, if you are using a GM driveshaft (car) with it may need a conversion u joint that mates 1310 or 1330 GM to 1330 Ford, got that? lol… There are many ways to go and there are many conversion u joints. I just did this and am using a Mustang 8.8 driveshaft to a GM 27 spline 1310 yoke for Fbody T56. Good luck. 1-0134, 2-1569, Spicer 5-134x, google them
