69 Chevelle ls turbo build
At least nothing was alive in there. We saw that a time or two. The project is looking great. If you plan to use a lot of stainless look at cobalt bits. They go through stainless like butter.
Looks good. A little on the hot side for the welds. When the welds are that dark and dull, that's a sign. Also try not to leave a divit at the end of the weld.
Try swirling the torch in a circular motion after the last dab of filler and hold the torch over it while the post flow is going and keep it there until the weld doesn't appear to glow orange. This works for me anyhow.
I really like your turbo layout and piping thus far. This is going to be a sick build for sure.
#34
Looks like our TIG skills are about on the same level...what are you using to TIG? Have you tried Pulsing?
I find pulsing at 1 PPS really helps get the dip dip dip just right..
