Any hope in selling 5.3 truck intake/accessories after swap?
Hey again fellas.
I'm pricing everything out here for the LS swap. The fellas over at nasty Z28 are saying that after they finished their builds on the 5.3, most of them wish they just went with an LS1 from the beginning. We need the f-body pan, an LS1/LS6 intake (if you don't have a cowl hood or just don't want to look at the damn thing) and need either new brackets to place the truck accessories properly or F-Body accessories altogether.
If I were to go the 5.3 route, buy all F-Body accessories, would I have any chance of selling the truck intake and accessories, or does nobody want them?
Thanks!
Thanks!
Truck engines aren't for everyone, but there seems to be a good market for the truck parts. I was able to sell my L92 intake, not for a lot, but some. I also sold my water pump.
I personally prefer the Corvette style accessories, so I always swap my balancer to the shallow Corvette style. On my current Cougar build, I started with a LH8, swapped balancers and water pump to the Corvette style. I am using the Holley alternator bracket, which word with a truck alternator. Pans are always tricky, but depending on what 5.3L you get, you can sell those. I sold the LH8 pan.
Remember, 5.7L LS1s are getting pretty old and there aren't that many around. Trucks engines can be had with less miles and are never. I also prefer the Gen IV engines with the 58 tooth cranks.
Andrew
Andrew
Thanks Andrew! The truck water pump has to be ditched when using an LS1/6 intake, correct? Also, any idea if the truck alternator/power steering pump are the same on the trucks as the F-Body? Probably not I'm assuming.
I'm wondering if I can use all the truck accessories in f-body brackets, in the f-body locations. If not, my options are:
1. Dirty Dingo brackets to move the truck alternator and power steering pump to f-body location
2. Do away with all the truck stuff and use f-body alternator and power steering pump with their respective brackets.
I don't have a cowl hood to fit the alternator in factory 5.3 location, plus I think it looks terrible there. I want the stock f-body positioning of the accessory system.
Thanks man!
Thanks man!
Thanks man!
Thanks man!
What's wrong with using the Holley bracket in the Corvette location? They also make spacers to use the same bracket with the f-body or the truck balancer.
Andrew
Alright thanks!
This is what i currently plan on going with - I can grab a 5.3 and retain all the accessories (except water pump)
Dirty Dingo low mount alternator bracket, f-body location with truck alternator:
http://dirtydingo.com/store/product_...oducts_id=1426
Dirty Dingo power steering bracket, f-body location with truck pump
http://dirtydingo.com/store/product_...oducts_id=1417
Which would look like this:
I am completely unfamiliar with the Holley bracket. Would I need the corvette parts?
Tons of info here:
http://documents.holley.com/199r10607rev5.pdf
As I said, you can use the truck alternator with the Holley bracket. You'll need a Corvette p/s pump and reservoir.
Andrew
Andrew
I'm running a truck acc & water pump with a LS2 intake - Cable throttle body - Twisted the neck slightly to clear and re-mounted the idler for the belt to clear the TB. Not running yet but I don't see any issues so far.
I bought a F-body alternator bracket from GM, it was a little cheaper ($50) but didn't come with the idler pulley (another $13 or so). I already had the F-body power steering pump, no idea on price of that. You can re-use the smaller truck alternator on the f-body bracket, the bigger Suburban and Tahoe units will not fit.
The 2007 and up NNBS trucks have the waterpump inlet at a different angle. From all the research I've done it will clear the TB with a car intake. I'll know in 2 weeks if mine will clear a Fast 102 with the truck DBW throttle body.
That car is f*cking gorgeous. I was originally planning on going with an engine from an 02 or similar. Early engine, early PCM.. just seemed to make sense. Plus I do not want drive by wire. I love the feel of a cable throttle.
Tons of info here:
Andrew
Andrew
A truck pump will not work with the Holley bracket. I have used an F body pump before, but it's not worth the labor to put a nipple on the end. The kit is built to use the corvette pump and sets the accessories up like the corvette drive system. IMO The Holley kit is the best aftermarket FEAD kit available.
Also, i cross referenced the part numbers for the water pumps, and Rock Auto showed that the F-body/Corvette water pump numbers were the same. Is this true?
If I read the Holley PDF correctly, with the Holley bracket I can use the truck alternator, and everything else from the corvette without needing the additional install kit. Does it HAVE to be from a 97 corvette, or is it all the years the LS1 was in the Vette?
Andrew
Hey Andrew, I just looked a bit further into the Holley bracket and see how it sits - lower than the truck drive does! Not bad.. it's growing on me. Will the truck p/s pump not fit on this? Someone on NastyZ28 mentioned reports of the accessory drive in the f-body location causing clearance issues with the pitman arm. Not sure if that applies to 70-73, gotta look into it more.
Brian,
I have the fbody accessories. My alt is close to the pitman arm, that is why my engine is set forward just a little. Drawback is the stock fbody pan did not clear crossmember without notching. The cts v pan should clear...but hangs below crossmember about 1/2". Kwik brackets (http://www.kwikperf.com/accessories.html) solve a lot of your accessory issues...nice but they add to your budget.
I'm getting ready to buy their A/C bracket.
Any C5/C6 power steering pumps will work. Not sure about the water pumps. You just have to be careful with the pulley depth. If you keep the truck balancer, you need to have a water pump that has a pulley in the same location. This is why I like to swap balancers to the Corvette style, because it sucks everything closer to the engine.
Andrew
Andrew
Brian,
There is a company on here that advertises smoothing one and custom paint/dipping for them. Probably wont get much for one, but you might try calling/e-mailing them about selling yours. If you leave the sensors on it, they may offer a little bit more. I do not know for certain. I sold 2 truck intakes and 1 was 100% complete right off the engine to someone for $110 shipped to his door. fuel rails, sensors, throttle body.... all was still on one intake.
