LQ4 good starting point?
I have a V6 camaro that I'm considering doing a swap on. Is an LQ4 a decent starting point? Do LS parts bolt-on? I basically plan on keeping the block and the crank and parting out the test of the engine. My goal is about 500hp N/A. I'm a noob to V8s so be patient. I've been a V6 guy for years. I know LS and LQ engines are a better starting point, but I can get this things pretty cheap.
I appreciate you replying. Now that I know the parts bolt on it will make it easier for me to do some research. I did use google a bit, but I wanted to be 100 certain before I buy the engine. Thanks again!
Look for a low mileage engine for a good foundation. A "cheap" engine can turn into an expensive rebuild very quickly. Yes, LS engines are reliable but like any other engine they leak, lose compression and burn oil eventually.
