Project Turburban! (1956 Plymouth Suburban with a 5.3 and GT45 turbo)
And another discussion on narrowing the Crown Vic cross member. I just did a quick scan but I think he kept the stock rack with relocated mounting tabs and shortened tie rod ends.
Tipsy
I like the idea of the mustang II stuff but they are pricey.
I glances over the articles you linked and will read them when I get home. Thanks for checking that out for me!
Sweet build! I look forward to seeing this done.
10 years ago I built a '57 Belvedere with an LS engine. Used a mustang 2 front clip. At the time a company called Retrotek made an electronic push button shifter- I used that in mine so I could retain push button shifting. Drove it to Tulsa in '07 to see the unearthing of the buried Bevedere, too.
Below is a link to the build (check the first ten pages or so- the other 50 are of my current project) for any pointers of what to do, or not to do.
Hope this helps
http://www.hotrodders.com/forum/jour...ge=5&reverse=0
Hope this helps
#32
Sounds good.
I might have made some progress on my front suspension, I have been researching narrowing the crown vic subframe. I have found a way to narrow it and keep the geometry correct I do believe, by swapping to a different rack and pinion.
Also, I ordered a 20 circuit wiring harness with fuse box and all the goodies to completely rewire the wagon. For not getting much accomplished on the car I sure am spending a lot of cash!
#34
Got home this morning and had my floor pans and inner and outer rocker panels sitting at my door step, so I had to open the boxes and check them out. They seem to be of decent quality.
Next up is yanking the old drive train out so I can start figment of the new crossmember. If anyone knows someone that wants a red ram hemi and push button automatic I will have one for sale soon!
