Water pump, front accessory question...
I bought a 2005 GTO water pump today because I want to use the pump with the front discharge. My question is what drive accessories can I use on the motor. This is all going into my 93 mustang swap on a LQ4 LS.
Thanks in advance,
Dogman
Thanks in advance,
Dogman
Holley makes nice kits that work with a variety of balancer and water pump spacing. They have a great PDF that spells it all out:
http://documents.holley.com/199r10640rev.pdf
Andrew
Dogman,
Andrew
Andrew
Thanks Andrew. I'll check it out.
water pump...
Thanks again.
You might look at this too, if you have a truck balancer and the water pump has the wide pulley. That way you can use the P/S pump and alt you already have.
http://www.scramspeed.com/products/s...tang-swap.html
