Suggestions for cleaning my dirty 5.3
Start with a heavy wire brush and purple power. Having access to a air gun will help too.
I'm cleaning my engine right now , not sure about the head chambers but as far as the rest of the engine ( external ) I have tried it all , and the best by far is mineral spirits in a spray bottle and a stiff brush end of story . spray on let it stand for a few minutes wire brush it around spray clean with more mineral spirits let dry . at least this is what worked best for me.
If it's mostly oily crap, I'd loosen the rockers as advised, flip it over and use a tooth brush and a cup of gasoline on the ports and mating surfaces (wire brush elsewhere). Once the heavy lifting is done, spray it with brake cleaner. Obviously, this would have to be done in a well-ventilated area, away from combustion sources.
