Corvette balancer and truck alternator low mount?
I currently have a Corvette balancer and am using the Holley alternator bracket that puts the alternator up high on the driver's side, like a C5/C6 Corvette.
The bracket works great and there are no issues, but I am tossing the idea of mounting the alternator down low on the driver's side.
Is there a bracket out there that will work with the Corvette balancer and makes this possible?
Thanks...
Andrew
Thanks...
Andrew
P1010268.jpg?t=1320876383
Seems like a pain in the *** since what I have already fits...but thank you!
Andrew
We have a bracket that mounts the alternator down low! Truck alternator works with it and it is on the Corvette belt line. We also have a power steering bracket that puts the pump above the alternator (CTS-V bracket). What PS pump are you using?
http://store.custombuiltmotors.com/e...r-bracket.html
Will this bracket work with the larger 130amp truck alternator?
How is the belt routing handles without a power steering pump?
Andrew
some info would be awesome since I am looking for a new option also. I have a elec race water pump and no accessories with a corvette ati balancer. I tried an f-body lower mount but it puts the alt to far out from the balancer. I have been running with the alt mounted to the block but there is no way to tension the belt. Does anyone make a low mount for a vette balancer and no accessories?
Not sure if it fits your needs but I built a low alternator bracket that put the alternator where the AC compressor was on the truck set up. Having issues posting pictures right now but there is a small shot of it on post #75 in my build thread. '47 Chevy COE, '03 Silverado It is adjustable.
Rob
Rob
I used one of these from IGT but I did had to make it work with my combo. Still have one of the c brackets if you are interested in it.
I Have the Vette bal and truck alt (forgot what amp it is)
