BRP Motor Mount dimensions 1st gen
Hi
Does anyone have a set of BRP motor mounts (engine side) that they can measure?
I bought an early kit from them and the steering hits the oil pan. Their later kits moved the engine rearward 3/4" to avoid this.
I don't have access to my motor mounts so I was hoping some one could help me.
I need these dimensions:
1) Width between the 2 piece coming off the engine plate. This is the length of the tube and bushing on the frame side.
2) The distance from the engine mounting to the center of the bolt hole for the bolt that goes through the frame mount.
3) The distance from the 4 mount bolts to the center of the bolt hole for the frame mount.
see attached
Thanks
see attached
Thanks
