what hole size for ls f-body wheel studs
I'm going to be putting C6 brakes on my 71 Cutlass. I want to switch to the larger 1/2 wheel studs. I'm using the drum hubs in front and f-body backing plates in the rear.
The f-body ls cars use 1/2" wheel studs, right?
What size do I need to drill out the drum hubs to fit the same size studs in that. I need to know exactly because this is a one chance mod.
Thanks
Thanks
Thanks
Thanks
http://arp-bolts.com/kits/Product.php?PL=55
Andrew
I used ARP studs for a Honda. I was able to used some sandpaper roll on a die grinder, and just home the stud holes till the marks from the old studs where gone. They are M12 studs.
